Mr_Mark1
Mar 28, 2015Explorer
Effy, the 2007-2011 Honda CR-V's were the same style (we had an '07). If your Honda has the Navigation, then you will need to have a fuse disconnect installed or pull the fuse manually which is not fun.
We had to have the same done on our 2013 Honda CR-V as we have Nav.
Both of our Honda's were set-up with the Blue Ox base plates, etc. Very clean set-up (looks). I had both done professionally so I don't know how difficult it was.
The M and G supplemental braking system was on the 2007 but wouldn't fit well on the 2013 so we went the SMI Air Force One system. Both work virtually the same.
Good luck and happy towing!
MM.
MM.
38,763 PostsLatest Activity: Dec 05, 2025
