ginagary
Jan 19, 2015Explorer
Gps units
We have a 2007 Winnebago Journey. We currently have a 2006 garmin streetpilot that we use for navigation. It has been starting to give us problems. What GPS navigation system do you all prefer?
I have two of the Streetpilot 7200 Garmin GPS units. I noticed some time ago that if I used one of the "splitters" used to connect two or more things to the single 12 volt outlet that my GPS unit had trouble acquiring the satellites. It would still power up and look fine but it still had trouble with the signal it was receiving from the satellites.
If that is the problem you are having and you are using a splitter, try hooking up your Streetpilot directly to the 12 volt outlet and see if that corrects your problems.
