dunl1492's avatar
dunl1492
Gravity Water Fill
Is there a way to fill the water tank of a Coachman Class C without "city" water under pressure? I will be visiting a CG without "city" water connections, but they do have a potable water hose, just no hardware to connect it to my inlet water port. Trying to use the potable water hose to fill my tank using just gravity. Any help would be great.
  • I have a Coachmen as well, and wanted to be able to fill my tank from some 5 gallon jugs. I thought I could just hook up a short hose and use a funnel to fill it through the freshwater fill, but there's a backflow prevention valve or something there that prevents it from filling unless the water is under pressure.
    So I bought an RV freshwater pump, attached hose fittings and wired it to my batteries, and used that to pump water from the bottles into the freshwater tank. I keep the pump around as a spare in case the one in the RV fails.
    If the hose you're filling from has good pressure, you might be able to use something like a water bandit to slip over the water source hose.
  • jdc1's avatar
    jdc1
    Explorer II
    I think he needs a "Water thief".
    https://www.amazon.com/Camco-Connects-Standard-Various-Sources/dp/B000EDOSKG/ref=sr_1_1?crid=3L6G2U4160R8N&dchild=1&keywords=water+thief+faucet+adapter&qid=1600194863&sprefix=water+thief%2Caps%2C288&sr=8-1
  • I assume you looked around on the exterior and didn't find a fill hole?
    If you don't: You could stop by the hardware store and pick up a garden hose end fitting. It would only take a minute or two to put it on, fill up and then 30 seconds to pull it off. Just have the fitting and a screwdriver handy by the front seat when you pull in.
  • The manufacturer did you a big favor by not putting a gravity fill on your mode. It "saved" you $7.29 or so! It's a good example of how they scimp and delete things we take for granted.
