rgatijnet1
Aug 11, 2015Explorer III
If you have slides, try them. If you have the same issues, then it is almost certainly a battery issue either with a bad cell or bad cables/ground connection.
Also try using your BOOST switch while trying the operating the jacks. If things get better, than it is definitely a battery issue.
