Sparkie616's avatar
Sparkie616
Grey Water Plumbing Dilemma
When I drain the kitchen sink in my '04 Fleetwood Fiesta, the water bubbles up in the bathtub. My first thought was that the vent for the grey water tank must be plugged, but I ran some water down that from the roof without any back-up. I've also run a snake through as much of the plumbing as I could (too many 90 degree bends!). I even had a guy come out and try to clean out the whole system, but that didn't seem to help. I've been very careful about what goes down the drain - scrape all dishes and dispose of oil and grease properly. The biggest problem seems to be that the entire plumbing system is built right into the floor; so I can't get at it without tearing up the floor. Anything I've missed???
  • Usually that is an indication that your grey tank is full. I will assume that is not the issue here.
    The vents for your plumbing are in the drain lines NOT the grey water tank. They are there to insure that the liquid drains quickly and does not create a vacuum situation. I think that any water entering your grey tank is creating a pressure situation and the water bubbling up in your bathtub is from water that is in the bath tub plumbing trap. I think the only way to eliminate the problem is that you need to somehow vent your grey water tank.
