hershey wrote:
I'm sure that your entire RV is GF protected. If you have two GF outlets, then each take care of 1/2 of your RVs wiring.
The GF will not reset if you don't have shorepower or the generator running adding power to the system.
If you have power to the system, then check your breakers on your electrical panel. Turn them completely off and back on to make sure you have a good set.
We discovered the problem when we connected to shore power for the night on our stop and the galley appliances didn't come on. We have power on at least 3 plug ins. We checked the breakers and all seem to be set good.
I have found 5 plugs not working and 3 plugs that are working.
