Cougarnewbie's avatar
Cougarnewbie
grounding new 12v branch circuit
My 12v dist. panel has a fused branch circuit that is not used. I would like to add a few small lights from that lead. My question is, what is the proper, safe way to ground it?. ...Hot wire to the switch, then to the lamps. Mounted on wood the lamps need a ground. Where do I connect the ground? I'm thinking a grounding bus for 12v in the converter, but I can't find it.
To clarify, I have an 06 Cougar 5er. The converter is a WFCO 8955. I want to install small lights in a large dark pantry. My converter has a neutral bus and a grounding bus on the A C side. I don't think I want to ground 12v to the 120 A C side of the box. I think Burbman had it right. I will check behind the converter when I get home.Seems like a common converter, so I will post what I find.
Thanks everyone
