BobGed wrote:
rondeb wrote:
We discovered the problem when we connected to shore power for the night on our stop and the galley appliances didn't come on. We have power on at least 3 plug ins. We checked the breakers and all seem to be set good.
I have found 5 plugs not working and 3 plugs that are working.
From this statement I'm going to assume this problem just occurred at whatever stop you're currently at. What happens when you start your generator? Are all the plugs hot? You also mentioned in a subsequent post that one of your A/C is not working. I would be very suspect of the power pedestal you're connecting to, but the generator test would confirm that.
The winner and the easiest to fix. DH unplugged the RV I turned on the generator and everything works so it is our power pole. Thank you for your response. We were getting ready to stay another day here and go buy new ground faults etc. WE can now move on down the road. Such an easy fix. I will know the next time.
Thank you for taking the time to respond.
