rgatijnet1 wrote:
They also make the inexpensive spring type tubing benders that work great for forming steel brake lines. These come in various sizes and you just slip the 8" or so long spring over the line, bend it, and pull the spring off. Then you use a double flare tool to form the ends.
Thanks for the spring idea, I see where you can buy them on line, do any of the local hardware stores, auto stores or HF carry a spring for a 3/16 hydraulic line? I am thinking this could also be used with the copper nickel or copper zinc alloyed tubes.
