- rvroamerrandyExplorerI will take a look and see if I can figure out what size fitting it requires and I will try and locate it on Amazon.
Thanks,
Randy - CA_TravelerExplorer IIIYou might also want to consider using DOT approved air lines. While I'm aware that some use whatever hose, clamps and fittings this could be a libiality issue.
Also be aware that the Air Force 1 controller requires 3 lines. One is a supply line that fills the aux air tank. The second is the metered brake line that controls a valve to release the aux air tank air to the third line to the towed vehicle. This setup is required to meet federal guidelines. - CA_TravelerExplorer III
rvroamerrandy wrote:
Those "hard to find" air fitting might be DOT approved and Amazon has some.
That's great advice. I appreciate that. I will work on getting the air fitting along with the gauge. Keep you posted.
Lets assume it is connected to aux brake, back in the past (2011, 2012)I was told it might just be an connection to a brake line without any additional systems on it (smi, Roadmaster etc.?) can this be true? Because I am having a heck of a time locating any systems down there?
Of course it might be a direct line to the brake system. Plus installed by the mfg gives the salesman bragging rights about the RV being set up for air brakes for the trailer or toad. Seems unlikely to me that they would install a SMI controller for example with the additional cost when they have no idea what the owner would want if any - an argument you could also apply to just an air line. - rvroamerrandyExplorerThat's great advice. I appreciate that. I will work on getting the air fitting along with the gauge. Keep you posted.
Thanks again for your great advice!
Randy
2011 Winnebago Journey 40U
2016 Jeep - Bikeboy57ExplorerMake up an air gauge screwed to a male disconnect. Put it in the fitting. If it is a aux brake system line it will not have pressure. Now press the brakes and see if you register pressure. You should see anywhere crom 30 to 90 psi depending on how firm your helper presses the pedal.
If you get pressure without pressing the brake pedal it is NOT an auxialliary brake line. - robatthelakeExplorerI was not able to find the correct fitting locally for the slightly used air brake system that I bought from a friend who no longer had the Motorhome!
I just had a standard air chuck installed on the rear of my coach which is tied into the coaches braking system.
I made up a new coach to toad connection hose using the right ends to adapt !
It has worked fine for the last five years and we travel 8 to 10 thousand each year! - larry_cadExplorer IIYou need a modulated air supply and should probably contact the chassis manufacturer for guidance.
- Bill_SatelliteExplorer IIThe connection to the air brake line is generic and not specific to the braking system. M&G, Air Force 1 or Blue Ox versions of air brake system will all be able to use your existing connection.
- oldaveExplorerIf you know what a regular air hose coupler looks like, the thing you would use
to couple an air impact wrench to. My Brake Master coupler on the coach
is about half that size. I think other systems use the same coupler, even if
it is different it will be easy to change. - rvroamerrandyExplorerwell I sure appreciate all of your help and responses. Again, I can see the air line but since I am in the market for a new system I was thinking about going with SMI Air Force 1. I hope this will make that install that much easier. I am towing a 2020 Chevy Trail Boss and I want to make sure I have done everything I can to protect my Investment!
38,782 PostsLatest Activity: Sep 10, 2026
