Ok looks like I probably have the OEM sway bars then. I may try and find a bushing kit for them, it is hard to believe upgrading on this small of coach would be worth the cost. Also will get the unit weighed and alignment checked to be sure the caster is at the 5+degree setting, I will also check the whole front suspension as well for worn items, and may add either a safe T Plus or the Roadmaster steering stabilizer. I think both products do about the same thing but the Roadmaster seems to be cheaper.
I think I will be very satisfied with handling if I make these minor adjustments. I will report back with what I find. Any thought on if the Safe T Plus is that much better than the Roadmaster?
