carringb
Mar 18, 2014Explorer
Does the "rocking" only occur when one axle makes the transition? Or both? If it is only rocking with one axle, it means the other axle does not have enough sway-stiffess, so a larger bar would be in order to balance the sway-stiffness. If it happens with both axles, your best bet is trying to lower the center of gravity followed by increased damper (aka shock absorber) valving. The stock Chevy 3500 dampers are pretty soft IMO.
38,782 PostsLatest Activity: Sep 02, 2026
