RvBill3
Mar 19, 2014Explorer
Snowman9000 wrote:
Our Sunseeker 2300 Chevy sure pitches side to side a lot when we encounter any bumps at all while turning at slow speed, such as leaving a parking lot. I have to go pretty slow, otherwise stuff will be flying.
It has sway bars, but would stouter ones help enough to matter? What else would stouter sway bars do to the handling and ride?
I have rear air bags, set to about the middle of their psi range. I have not experimented with them.
I think what you are describing is pretty normal. You can lower air in air bags a little and see if that helps, but if I had to choose handling on road vs. pulling out of driveways, I'll set air bags for the road every time.
I use to drive a sports car that required taking transitions very slow so as not to drag bottom. It just became second nature. I think you will find that to be so with the MH after awhile. I would not spend money on new equipment until you try different settings on air bags and "just get used to it".
38,782 PostsLatest Activity: Sep 02, 2026
