j-d
Mar 19, 2014Explorer II
Your gasoline tank, furnished by Chevrolet, may be baffled inside. Even if not, it's probably installed lengthwise in the chassis, so gasoline shifted side to side doesn't have all that far to "slosh." Are your water tanks (fresh, gray, black) installed crosswise under the coach body?
This may sound counterintuitive, but a warship with a damaged, partially flooded compartment will often choose to flood it fully. The partially filled compartment is more de-stabilizing than it would be fully flooded despite the additional weight. It's called "Free Surface Effect." If you had three tanks, each half full, mounted crosswise, I think you might feel the surge of the combined weight of the water.
38,782 PostsLatest Activity: Sep 02, 2026
