Gene_in_NE
Mar 19, 2014Explorer III
Snowman9000 wrote:As others have stated, the difference in height can make a difference in rocking side to side. That A/C on top is about 7" higher than on your previous motorhome. A 2005 RVision Trail-Lite 213 was 10'-8" while the 2014 Forest River Sunseeker 2300 is 11'-3". You also have a much heavier looking cab-over. I'm fairly certain that your Trail-Lite gas tank was lengthwise and between the axles and so was your fresh water tank.
Our Sunseeker 2300 Chevy sure pitches side to side a lot when we encounter any bumps at all while turning at slow speed, such as leaving a parking lot....
Handbasket probably has the best suggestion of varying the air pressure in your air bag. I would start by dropping the pressure from 50 to 40, then 30...until 10 psig. I doubt you need to be above 50 as that 4500 should have enough spring to hold your weight.
38,782 PostsLatest Activity: Sep 02, 2026
