Snowman9000's avatar
Snowman9000
Handling: Rocking and Rolling: UPDATE
Our Sunseeker 2300 Chevy sure pitches side to side a lot when we encounter any bumps at all while turning at slow speed, such as leaving a parking lot. I have to go pretty slow, otherwise stuff will be flying.
It has sway bars, but would stouter ones help enough to matter? What else would stouter sway bars do to the handling and ride?
I have rear air bags, set to about the middle of their psi range. I have not experimented with them.
  • If the air bags are plumbed to a single fill or gauge, that's for sure aggravating the issue. Too much air and not enough shock can, too. The air is not self damping like a steel spring. A minor help may be to pack dense stuff like canned goods down as low as possible. I'm assuming correct load range tires and tire pressures.
    But I don't think there's any way to stop all the body roll in those situations. There's just too much mass up too high. Stiffer sway bars may help some with that situation, as well as with parked stiffness, but don't expect night and day changes.
    Jim, "Feng shui: An ancient Oriental art for separating money from the gullible."
  • From my experience this is the case of the "box house" just following the rear axel. I think we would need less anti sway stuff as opposed to more anti sway stuff. JMO.
