Effy
Jun 30, 2014Explorer II
jerseyjim wrote:
Check your tire pressure. Too much can be part of the problem. The shocks, (Bilstein?) if they are worn will not create a "hard" ride. Just the opposite. You don't say the age of the motorhome. If it is older and has original tires, that might be a problem too.
Bad winter...roads are still damaged. Maybe part of your problem. Radio OK otherwise? So many possibles.
x2 - weigh your coach and set PSI according to the tire chart. I was way under the weight on the sticker and way over PSI. Set it right and 100% improvement.
38,766 PostsLatest Activity: Jan 10, 2026
