brirene
Jun 13, 2013Explorer
Passin Thru wrote:
Just had TT waxed last month at CW. Should I wait and use Barkeeps friend in the fall and do Zep then or would it stick to new wax? Never seen the stuff and just now reading about it.
If you just had it waxed, I would wait until you're no longer happy with that finish, then do the zep process. The trick to zep is to remove all traces of wax, soil, etc. so that it does adhere directly to the surface.
BTW, if you're happy with the finish when waxing, you might not need zep. It came about as an answer to surfaces that had oxidized and no longer looked good even after repeated waxing. If your finish is good yet, you may be just as happy with continued waxing at this point.
38,707 PostsLatest Activity: Feb 28, 2025
