rk911
Nov 29, 2019Explorer
regarding the power...
- 50 amp or 30 amp coach?
- check for a tripped GFCI outlet in the kitchen, bath. your power out on one side almost screams a tripped GFCI
- if that's not the problem disconnect from shore power and start the genny. if all electric is working your problem is likely at the post. if problem persists you may have missed a GFCI
ref the LP...simple things first...
- lp tank full or at least not empty? supply valve on?
- was furnace working before?
- will the stove light?
