larry_cad
Nov 29, 2019Explorer II
majordad wrote:
Thanks for the many suggestions.
I should have been more specific, we are staying with family here in Texas. I am plugged in to a 30 amp plug just to keep things charged up, that’s why I was trying to run the appliances on propane so as not to take too much electricity and that is how I came to find no 120 V power on passenger side of coach, save for 1 outlet in the bedroom. I am going to try and locate transfer switch in the morning before we leave and check voltages. Will let y’all know what I find, but the kids have to be back to school Tuesday so we gotta get going.
Merrill
If you are using a 30 amp adapter in a 50 amp coach, it is very possible the adapter is defective. Get a new 30-50 amp adapter and it likely will fix the power problem.
If your batteries are low, someone suggested your propane shut off solenoid may be off, not letting propane to flow.
Finally, I had to repair a Magnum inverter that had a bad circuit breaker, leaving it with only one output circuit and the other one dead. May be a bad inverter circuit breaker.
