Executive45
Nov 30, 2019Explorer III
The other day I started the coach as the batteries were low and let it run for about 15 minutes. I also Reset the a/c out 1 and 2 on the inverter and when I checked the bathroom lights, they came on.
Since you apparently 'fixed' it once, your issue seems to be easier to decipher. It would appear resetting the inverter, (if I read your post correctly) fixed it the first time. Check those and see if they need to be reset again. If so, you'll need to find out why they are tripping. First place I'd look would be at your friends' pedestal. Many people, electricians as well, don't understand or use the correct equipment when installing RV pedestals in their homes. The suggestion of running off your generator is good advice. Your batteries need to be fully charged also....Dennis
