time2roll
Dec 01, 2019Nomad
majordad wrote:I think it might be the 30/50 adapter. Check voltage on the main 50 amp breakers in the main panel. Post the results.
Turning on the generator has given me back the missing power, so do you think the transfer switch is failing. We are in a rest area 150 miles from the New Mexico border and heading home.
I have read about a propane detector that may cut off propane and may need power applied to get the propane moving. Check and post the battery voltage while you are poking around. If battery voltage is good check for 12 volt power at the 12v distribution panel to verify the stack of fuses are same as battery voltage.
