charwan
Aug 21, 2016Explorer
Take a test light and check for power at the flasher. If power then fuse is good. Then start checking where bulbs are plugged in and work your way to the frt. If no power at flasher take test light and test all fuses. My 04 has fuses outside under hood and also under dash. If fuses are good and no power at flasher the next thing is turn signal switch. Don't go by a fuse looks good. Use 12 volt test light. Power should run from fuse to switch to flasher to bulbs. Hope this helps
