charwan
Aug 22, 2016Explorer
Them little minie fuses are hard to see and so a test light is best. Yes, signal lights and 4 way flashers are on two different circuits. You can test the fuses thru a small pin hole in the top for each contact. You need a test light in the MH anyway. I would first find the correct flasher and see if it has power. You want the flasher button in or out as it is on some to test the flashers.
