- bobndotExplorer III
pushtoy 2 wrote:
bobndot wrote:
Use a long #2 Phillips screwdriver . There is an access hole above the headlight with a long downward reach to the adjuster on the back of the light housing. The adjuster is very easy to turn with no or little resistance.
thank you for your reply have to look for that
Locate things during daylight hours and use a narrow beam flashlight to look about 12-14" down the nickel size hole to view the adjuster on the back of the light housing. Once you done that, its a lot easier to do the adjustment in the dark.
My adjuster is so loose, it didn't seem like it was doing anything...felt like it was broken, just spinning.
If you watch the headlight beam against a wall , you will actually see the beam move up and down, depending on clockwise or counter clockwise adjustment. - pushtoy_2Explorer
thank you for your reply have to look for that - bobndotExplorer IIIUse a long #2 Phillips screwdriver . There is an access hole above the headlight with a long downward reach to the adjuster on the back of the light housing. The adjuster is very easy to turn with no or little resistance.
- azdryheatExplorerYeah, take it to a mechanic - but only if you want it done right. BTW, how many times did you post this question?
- 2oldmanExplorer IIyoutube may know.
38,763 PostsLatest Activity: Dec 13, 2025
