mikeleblanc413
Mar 15, 2014Explorer
rmasonschneider wrote:
mikeleblanc I would be very interested in the details of the change. I was just about to order a set as well for the same reason. if you don't mind that is.
He showed me two pull up clips on each end of the top of the light. Pull each clip up (he had to use pliers on one), be sure to be holding the light, unplug the connection. Reverse the process and it's a done deal. Took him maybe 5 minutes. Hope this helps.
38,783 PostsLatest Activity: Sep 22, 2026
