racer99's avatar
racer99
headlight replacement
2000 Fleetwood Flair/30'/V-10/F-53 chassis
We have a headlight that keeps sweating inside which causes water beads and have tries numerous times to correct situation and have had headlight out couple different times-QUESTION is does anybody know what bulb replaces these-It has on bulb TYC 20-935---SAE HR92-I came up with a 1996 Bronco -BUT if anybody knows I'd appreciate your knowledge-RICH
pauperspride.blogspot.com
  • Had the same problem with my 2003 Southwind, found the style of headlight and used JC Whitney to find a replacement set. $150/ea., the cheapest I could find. very happy with the replacement. Came with the bulbs. Just an FYI
  • Clicky
    Does it look like this one on Amazon?
    You need to replace the whole assembly not just the bulb.
  • You can Google your numbers you have. Mine are the same as my 1997 Ford F-250 and I picked them up on e-bay. Jim
  • Looking to replace whole headlight assm.-Thanks Rich
  • Are you wanting to replace the bulb or the entire headlight assembly? The TYC number you have generally is for the entire assembly. It may very well come from a Ford Broncho. The headlight assemblies on my coach are same as those on a Lincoln Navigator. Amazon generally has the best price on those replacement assemblies.
