DrewE
Apr 29, 2015Explorer III
coolmom42 wrote:
Could be you need to polish the lenses to remove the surface oxidation. That might make a huge improvement. I've done this on every car I've owned that was over a few years old.
You can get kits to do this at auto supply stores or Costco. Be sure to put on some UV protectant afterwards.
That's great advice generally, but hardly applicable to the glass lenses on sealed beam headlight bulbs. The poster has a different light setup than a typical class C motorhome because most if not all of the class C builders opt for the higher trim level chassis with fancier headlights. I think it may even be part of Ford's standard motorhome prep package for the E series chassis.
38,782 PostsLatest Activity: Sep 02, 2026
