Mote
Jun 12, 2015Explorer
If there is hot air coming from the engine compartment then you have a leak thru the seal of the engine cover. I would want to get that fixed as quickly as possible as that could also allow engine fumes to engine the vehicle.
If the engine cover is getting hot from the engine and then that heat is burning your legs then as others suggested you'll need some type of reflective insulation to stick to the inside of the engine cover.
38,782 PostsLatest Activity: Sep 10, 2026
