Photomike
Dec 01, 2016Explorer III
Jerseydevil wrote:
I am going to take another crack at it this weekend.
Plugged in- Check
Tstat batteries changed- Check
Fuses in converter changed- Check
Propane in tank- Check
Gas at range- Check
Interior lights on- Check
Keep any other suggestions coming. Thanks
If the Tstat & furnace has a fan only setting try that - if fan runs then you have power.
If it has air/heat turn to air then back to heat - can stick even when it looks like it is on heat
Have someone turn Tstat on to heat and stand out by the vents - do you hear the pre fan turning on? Do you hear clicking?
If manual Tstat turn up to the highest setting.
