JackMSExplorerJan 06, 2014Heat pump working at 28 degrees ambientI did an experiment with my heat pump tonight. Wanted to see at what temp it would switch to the furnace. It is down to 28 right now and the heat pump is still running blowing 104 degrees out the vent...Show More
wallynmExplorerJan 06, 2014Would guess your roof temperature is a little higher than your outside thermometer.
Related ContentNot all Aftermarket bumpers work2003 newmar freightliner speedometer stopped workingCamping at 27 degrees.Ambient Temp Sensor TroubleshootingHow important is 90 degree turning?
