dougrainer
Jan 07, 2014Nomad
The Ambient Temp Thermister for a Dometic is in the 34 to 38 degree range. BUT, the Thermister is NOT completely exposed to the outside. It is on the inner case frame under the plastic shroud, and IF the HP is running and producing heat, THAT small amount of heat will affect the Ambient sensor. So, it is possible for a HP to run in ambient temps lower than that 34 to 38 degree setting. The Wall tstat has a 5 degree up or down margin of error according to Dometic, so it is possible the Ambient sensor also has that margin up or down. Doug
38,782 PostsLatest Activity: Sep 10, 2026
Related Content
- Feb 01, 2026Community Alumni
