dougrainer
Jan 07, 2014Nomad
rgatijnet1 wrote:PastorCharlie wrote:
Probably the units have heat strips that result in blowing out the hot air once the temp drops below about 40F.
Nope, a heat pump is just a heat pump. Some older RV AC/heat units do have heat strips(usually about 5K btu's) that put out some heat but they are not advertised as heat pumps. The newer RV heat pumps are just more efficient and able to work at lower temps than the older units.
There NEVER was a RV Heat Pump until about 1998/99. Before that they just had RV AC units that you could install an optional 5600 btu Heat Strip to utilize to warm up the morning chill or evening chill. NOT to heat the unit at all. Rather than using the furnace to take that chill out, you used that Heat Strip. Doug
38,782 PostsLatest Activity: Sep 10, 2026
Related Content
- Feb 01, 2026Community Alumni
