dougrainer
Jan 07, 2014Nomad
JackMS wrote:
The reason it only got to 42 inside was because i had the therm set on 40 degrees. I dont winterize for a few reasons so was turning on furnace because of the freezing temps. Was just curious what the heat pump would do.
I have dometic penguins. Dont believe they have heat strips. In fact dont even know if a heat pump can also have a heat strip.
Yes, they can, but kind of redundant and a waste of money. Remember one thing, MOST basement water areas NEED the furnace or Hydronic heating system to keep the bay water systems from freezing. A RV Heat Pump will NOT do that. It ONLY heats the interior of the RV. Another reason to have the system shut down and go to furnace if it gets below 32 degrees. Doug
38,782 PostsLatest Activity: Sep 10, 2026
Related Content
- Feb 01, 2026Community Alumni
