johnwalkerpa1
Jan 07, 2014Explorer
JackMS wrote:
The reason it only got to 42 inside was because i had the therm set on 40 degrees. I dont winterize for a few reasons so was turning on furnace because of the freezing temps. Was just curious what the heat pump would do.
Ah, ok! That makes sense.
One thing though, I wouldn't put a lot of stock in the effectiveness of your heat pump based on the thermostat being only set at 40. Just because, you are asking a whole lot less of the heat pump to heat the air from 28 to 40, then if you were trying to heat it from 28 to 70.
I am not saying that it won't work...it very well might, just that your parameters may be a little skewed in this particular experiment...
38,782 PostsLatest Activity: Sep 10, 2026
Related Content
- Feb 01, 2026Community Alumni
