BTWHITIS
Jan 09, 2014Explorer
heat pump
I have a 2012 Bounder 35K. 2 air units. the rear air unit is also a heat pump, the front unit seems to be only air. Should both these units be heat pumps? The rear unit will put out heat, it seems the front unit will only produce cool air unless the rear unit is on. Seems the front unit only moves warm air from the front unit when it is on. Hard to adjust and even temp through the motor home. Anyone got any ideas?
