Dale_Traveling
Jan 08, 2017Explorer II
Don't overlook 12VDC power. All the items mentioned, water heater, thermostat, furnace and fridge use 12VDC for the controllers. The furnace also needs it for the blower. If you're plugged into shore power you might not notice unless you happen to turn on a ceiling light.
A second potential trouble maker(s) are the CO detector and propane detector. Depending on your coach you could have an automatic shut off valve on the propane line that either of both control. To add an additional twist both are 12VDC powered and I don't know how they would react if power is less than optimum.
