BigMac
Dec 13, 2014Explorer
Heater and A/C Dash Controls Not Working
I own a 2004 Forest River Georgetown. It's on a Ford chassis. Today I took it out for a spin to give it a little exercise and noted that I could not turn on the heater. Turns out none of the heater, defrost or a/c settings elicit any response from the blower motor. They all worked fine on our last trip before I put it back into storage. I'm not much of a mechanic, but I did check the fuse panel for blown fuses (none found), and I checked the connections to the selector nobs to see if any had come loose, but found nothing. The fuses I checked were:
They were all good. If anyone has had a similar experience and was able to work thru it, I'd appreciate some suggestions. I'm not sure if this is a selector switch issue, or fan speed switch issue, or what. Thanks
- #5 - Body builder accessory feed (accessory and run)
- #7 - Blower motor relay coil
- #14 0 Warning chime module, Power
brake assist module*, Instrument
cluster power, Instrument cluster
warning lamps, Transmission
control switch - #38 - Body builder accessory feed (run
only)
