dianna119 wrote:
Thanks Doug, makes sense. I can hear the furnace burner shutting down and fan stays on. I have left it on for upwards of an hour thinking it should shut off and just blows cold air making the inside cold again and then burner comes on. In previous years, the fan would shut down after about 2-3 minutes. DiAnna
just saw your ps, Yes, the thermostat was replaced same brand/type as original,
Odds are the Hi temp control tstat of the furnace is BAD. It is NOT opening the tstat when the furnace has cooled down to shut off. It is a Bi-Metal disc and after years of use is probably just worn out. It needs replaced. Doug
