dougrainer wrote:
YC 1 wrote:
I am betting low voltage at the fan is causing the vane switch to not allow the ignition sequence to start.
Time to check the voltage with the fan running right at the heater wires.
Of course a quick battery check would be in order to start.
The OP is NOT having a Lighting problem. They are having a fan NOT shutting OFF after a Heating cycle is complete. Doug
". I can hear the furnace burner shutting down and fan stays on."
If the voltage recovers enough for it to light and come up to temp the voltage could be pulled down enough for the fan to slow and not allow the furnace to light again. I have seen this happen and you end up with a dead battery and cold rv.
Low voltage is easy enough to check for.
