ArchHoagland
Jun 07, 2014Explorer
ccxnola wrote:
You can get close to the correct actual measurement with some of the previous suggestions. Here is a method to be sure:
1-Park the MoHo and make it level.
2-Place a long 2x4 across the roof on top of the highest point.
3-Use a level to make sure it is correct at both sides.
4-Measure from the Underside of the 2x4 to the ground.
That is your actual - you may wish to add something for 'clearance'.
Bend-able antenna are not usually included - but a TV antenna in the 'up' position when going under a low bridge can ruin your day and cost big $$$ if you damage the roof as it is pulled over.
JMHO!
That's the correct method that I used.
I then taped a paper with the height on the top left inside corner of my windshield. I gave my self a two inch buffer just for the heck of it.
38,766 PostsLatest Activity: Jan 10, 2026
