S1njin wrote:
I'm considering putting a hellwig front and rear sway bar on my 2018 E450 chassis.
Can somebody surmise torque specs for the front AND the back sway bars? Bolts throught the links/arms, bolts through the plate, etc.?
Roadmaster give you torque specs, but Roadmaster also wants me to drill. I don't want to drill so its Hellwig or bust.
In my experience with Hellwig their instructions will give you the specs and are available on their website.
sdtrucksprings.com had the best prices that I found. I have purchased four different bars from them and have been happy.
My research in the Hellwig vs Roadmaster came up Hellwig every time. The steel and the diameter was always the same. Mounting and the downlinks had a difference which I bet is simply a work-a-round for patents. Price always went to Hellwig.
IMO customer service is a slight edge to Hellwig. On my first install on the front of a 2007 E-450 I called them when I couldn't figure out something simple. As soon as he started talking it was plain the beer confused the instructions. Had a good laugh. Since them then I have talked to both on bars for my 2016 F53 and with RM on their RSSA.
EDIT: I just looked around Hellwig and SDTrucksprings sites and couldn't find the information you need. I would certainly contact Hellwig they do respond promptly. Please contact techsupport@hellwigproducts.com for a current instruction sheet. When I did my E-450 I only used a 1/2 drive ratchet and flexbar but I don"t recall using a cheater bar on it.
