wildmanbaker
Aug 04, 2016Explorer
It is a Fleetwood product, and should be able to operate everything on 30 amp service. The breakers do not trip on low voltage, but high current draw, which causes more heat. If the supply voltage is above 115 volts, then I would suspect that the main breaker is getting week and should be replaced. As mentioned above, check breaker connections, and main feed tie in for tightness, as this will cause excess current draw. We have run ours on 30 amps in 104 degree weather for 5 days before with no problems.
Good luck.
Good luck.
