wildmanbaker
Aug 05, 2016Explorer
Blackdiamond wrote:
Water heater was not on, water was already too hot coming out. Fridge was on electric.
I will check the connections. and see if that is the problem.
One thought I had.....I put in a inverter/3-stage charger and the charger can draw up to 40 amps but the batteries were full so it should have been drawing 5 amps, is that something I should check out?
Do you mean it puts out 40 amps? If it draws 40 amps AC, then that is the problem. As mention above, a clamp on amp meter will help pinpoint the problem.
