bsinmich
Aug 05, 2016Explorer
You said you had 1 AC on and the microwave. A full size microwave will draw the same as the AC. I did run 2 ACs on my '96 Pace Arrow with no problem. When you run the generator it is probably 5KW or that area so you are producing enough power but your ATS has eliminated the plugged in circuit for any power. You can only draw power from one or the other and the RV will default to the generator. Low voltage at the power pole sounds like the likely culprit.
