Old-Biscuit
Jun 12, 2015Explorer III
Level?
Freezer freezing.......food section still warm. Blockage in cooling unit between low temp evap section (freezer) and high temp evap section.
When you moved it due to flooding.....you unplugged shore power/fridge swapped to propane. You parked RV on higher ground.......but it probably wasn't re-leveled.
Fridge operation in an off level condition can cause blockage in a cooling unit after less than 20 mins. of run time.
Test cooling unit.......
Unplug electric heat element and plug it directly into an AC power source.
Run it on direct AC power for at least 12 hrs.
Then check temps in freezer and food section.
If food section still warm cooling unit is blocked.....replacement time
