J-Rooster
Sep 20, 2014Explorer
Michelins Tire Website has information on there website that can help you! First of all you need to buy tire covers to keep the sun and UV rays off your tires when the coach is not being driven. You can purchase them at Camping World and they are the best tire protector from the sun. Michelins Website on tire care says to use only warm soapy water to clean your tires. Most tire UV protectants use a petroleum base in there products and anything with petroleum base should not be used on rubber surfaces so check the labels on these products to see if there petroleum based. Michelins Tire Care Website says you can drive a tire with UV cracks on the sidewall but, I can't remember the diameter that is allowable your going to have to find that information out yourself on Michelins Tire Website.
