wolfe10
Jul 21, 2013Explorer
ASSUME your DP is a REAR RADIATOR.
Access the top of the engine (bedroom or closet). Shine a strong flashlight inside the fan shroud/between fan blades. You are looking at the front of the CAC (Charge Air Cooler). It "filters" the dirt thrown at the cooling package by the fan and needs to be cleaned FROM THE FRONT at least once a year.
Confirm that the perimeter, particularly lower perimeter is as clean as the center (the blades sling the dirt to the perimeter).
38,708 PostsLatest Activity: Mar 05, 2025
