MountainAir05
Mar 13, 2017Explorer II
Gjac wrote:
Put a piece of white paper where the drip is. If it is from the transmission it will be red, if from old engine oil it will be brown, if from your hyd levelers, it will be clear. Wipe all surfaces underneath MH that is oily looking. The first pan you see(up front) will be the oil pan, the second one is the transmission pan. The leak could also be coming from one of the lines like a brake line. Once you wipe every thing down it will be obvious we're the leak is coming from.
Might want to add that some Hyd levelers use red fluid also
38,782 PostsLatest Activity: Aug 30, 2026
