- eric1514Explorer
dougrainer wrote:
Thanks again, man. We're lucky to have you around!
That is exactly what that noise is. The clutch and it is normal. Doug eric1514 wrote:
dougrainer wrote:
eric1514 wrote:
trailrider wrote:
Yes it does, Thanks.
It looks similar to a system Newmar made for their motorhomes.
While it looks similiar it is NOT a Newmar style. The system is currently a LCI(Lippert) supplied system. BTW, Newmar slide systems except for the HWH they use is Patented by Newmar, so not other OEM will be using that system. If you are looking for the Motor/actuator, this link will direct you to just one of your style. Doug
https://store.lci1.com/slide-out-room-actuator-with-18-to-1-venture-motor-various-sizes-room-actr-18-1-vntr-mtr-assy.html
Thanks, Doug
The system is working well. I just wanted to learn about how it works. I see that actuator running parallel to those tracks.
For instance, at the end of the slide’s travel something makes a rapid thunk, thunk, thunk. I try to limit it to one or two but maybe it’s just a normal sound it makes, like a clutch.
That is exactly what that noise is. The clutch and it is normal. Doug- eric1514Explorer
Thanks, Doug
For instance, at the end of the slide’s travel something makes a rapid thunk, thunk, thunk. I try to limit it to one or two but maybe it’s just a normal sound it makes, like a clutch. eric1514 wrote:
https://store.lci1.com/slide-out-room-actuator-with-18-to-1-venture-motor-various-sizes-room-actr-18-1-vntr-mtr-assy.html- eric1514Explorer
It looks similar to a system Newmar made for their motorhomes. - trailriderExplorerIt looks similar to a system Newmar made for their motorhomes.
- eric1514Explorer
enblethen wrote:
I tried that but Dynamax sprayed the motor with undercoating and it's difficult to remove. As a last resort, I'll try that.
Look around the drive motor for manufacturer information. - wanderingaimlesExplorerYou tube has more than one video on identifying them. Here's one
rv slides - Look around the drive motor for manufacturer information.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
